Leak
246,600 MILES • 5.0L • V8 • 2WD • AUTOMATIC
CARLA REED
  • 27 POSTS
Daughter noticed there was a small amount of antifreeze on top of motor. Radiator/reservoir is full.
Thanks,
Carla Reed
Nov 23, 2018 at 11:38 AM
Good evening,
That could be the thermostat housing or the hose.
You need to have a pressure test done to pin point the exact leak. Once that is done and the leak found, let me know what the failure is and I can advise you on the repair.
https://www.2carpros.com/articles/radiator-pressure-test
Nov 23, 2018 at 11:52 AM
CARLA REED
  • 27 POSTS
Thank you for your quick response. We will give that a try.
Nov 23, 2018 at 12:46 PM
You are welcome.
Always glad to help.
Nov 23, 2018 at 12:49 PM
