LC9 5.3L Gen. IV Crankshaft Machining
186,000 MILES • 5.3L • V6 • 2WD • AUTOMATIC
MCH86GN
Hi guys,
I watched your series on YouTube, rebuilding a GM LM7 gen. III 5.3L LS motor. During the assembly process of installing the rotating assembly it was mentioned that if the crankshaft needed to be machined or turned that it would have to be heat treated and that cost around $300.00, in addition to the cost of the machine work.
Well, I am rebuilding a GM LC9 gen. IV 5.3L aluminum LS block. I just recently dropped the block, main caps, and crankshaft at the machine shop. One of the items is turning the crankshaft .010/.010 and then polish. I understand that this crankshaft is out of a later model year than you were working with, but I am pretty sure that are the same. Both are nodular iron, and both went through the same manufacturing processes. So, the question is, if the crankshaft has to be turned .010/.010 should it be subject to additional processes like heat treating? Because a new 0 miles crankshaft from GM Parts Direct is $245.00, plus $80.00 for shipping. That comes to $325.00for the new crankshaft and it might need to be polished at most. If the cut crankshaft has to go through those additional processes or should, it will be at least $500.00. That's more than I paid for the entire short block assembly. Any input is appreciated.
Thank you,
Charles
Dec 14, 2021 at 8:04 AM
RYAN L
  • 273 POSTS
Hey there,
Thanks so much for watching our series!
It is my understanding that yes it would have to be heat treated again. When I talked to the guys that machined our block they told me it is almost never worth it to go 10 under on a LS crank and if it is in good enough shape to resurface it and run it stock size. That heat treatment is so expensive you can just buy a crankshaft for less money.
Thank you for using 2CarPros!
Best regards,
Ryan
Dec 15, 2021 at 2:15 AM
