Late response on throttle - Limp mode?
320,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
DEADMANWALKING3
When i start my car in the mornings or after long time after work and i put it drive i get no response not even slight movement. When i put it to reverse it starts moving without any amount of acceleration given.
Feb 13, 2019 at 1:38 PM
  • 55,710 POSTS
This is common when the throttle actuator gets dirty causing the car to go into limp mode and act funny. Here is a guide that will help you fix the problem:
https://www.2carpros.com/articles/reduced-power-limp-mode
Feb 15, 2019 at 11:06 AM
