Will not start, 4LO and check lights are on
2011 TOYOTA LANDCRUISER
98,000 MILES • 4.0L • 4 CYL • 4WD • AUTOMATIC
WALELAMI
Vehicle listed above is a Prado. The car did not start as and check lights are on. I change the battery to new one still no change. Though this had happened before, and we did scan but reported no error or code. We then decided to check the earthing/ground of the car still no change. The car was left for a period of about a week and then crank the car and it worked until after it was parked for about 1.5 months and the same issue occur again. Your advice please.
Thank you
Oct 24, 2021 at 8:30 PM
  • 110,240 POSTS
First, please understand this vehicle isn't offered in the US, but I will try my best to help.
When you say it won't start, do you mean the starter motor doesn't engage, or does it turn the engine, but the engine fails to start? I need to know that.
Until I hear back from you, take a look through these two links. One explains how to test a starter motor and the other is for a crank no start condition. Let me know if they help.
Oct 25, 2021 at 12:48 PM
