1977 Land Rover Series 3 clutch problem
1977 LAND ROVER SERIES 3
SPLITTERZZ
Transmission problem
1977 Land Rover Series 3 6 cyl Four Wheel Drive Manual unknow miles
clutch will not disengage. Cannot select gears with engine running. When engine off and gear selected and clutch pedal depressed the vehicle jumps forward on the starter motor a little as if it is being started in gear. I have overhauled and checked the clutch master and slave cylinders. There is nowhere to view what is happening at the clutch face. A friend has suggested towing the vehicle with the engine running and trying to slam it into top gear to unfreeze?
Aug 28, 2010 at 10:32 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there, do you have good pedal pressure? doing what you friend says may do serious damage, there is no way of viewing the clutch ass with out removing the transmission, you can see if the slave is operation with the pedal being pushed, if this is ok and you still have problems, the box will have to come out.
mark (mhpautos)
Aug 29, 2010 at 1:05 AM
