Power steering reservoir help
BARRY CHILDS
Hi, I have a 1986 Range Rover. The power steering reservoir has a large metal cap with a coil spring and some sort of widget in it. There is no dip stick or indication of where the level should be. It looks to be low, below the level of what looks like a metal float under the spring. I haven't seen anything like it before. Can you help???
Nov 20, 2007 at 8:07 AM
MERLIN2021
  • 17,250 POSTS
I don't know what you are describing! Here's the exploded view of 86 Ranger Power steering pump! Is this your part?
https://images.2carpros.com/forum/automotive_pictures/62217_PSPump1_1.jpg
Nov 20, 2007 at 8:14 AM
BARRY CHILDS
It doesn't look like that, but iv'e just been told it is a 'jam tin' earlier type with a strainer. Thanks for your help. Donation on Friday!
Nov 20, 2007 at 8:49 AM
