2006 Range Rover Transfer case
86,000 MILES • V8 • 4WD • AUTOMATIC
DEAN SAGER
After driving through a puddle the tranfer case has a grinding noise like it stuck between 2 wheel drive and 4 wheel drive. what is the cause and how do I repair this?
Feb 21, 2010 at 12:58 PM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated Start by checking fuses 33,35 and 37 in central fuse/relay box also check fuse 17 in battery fuse/relay box .. if these are good check wiring connecors on transfer box motor ! Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_985.png
Feb 21, 2010 at 11:59 PM
