2006 Range Rover Sqealing Brakes
2006 ROVER RANGE ROVER
67,000 MILES • V8 • AWD • AUTOMATIC
TAXES
I bought this vehicle a couple of months ago. In this last month the brakes have started to squeal and extremely loud. My first thought was it was a brake wear bar and I called the local dealer and was told this model doesn't have a wear squeal bar, but I should bring it in so they can take a look. So I went to the dealer, and a tech took it for a drive, and did a short visual all in my presense and said the brakes are in great shape but my rotors needed to be turned, and quoted me $400 for the job. I wanted a second opinion so I took it to a local brake shop(Midas) and they did a complete brake inspection, they told me the same thing that my brakes were in great condition but my rotors needed to be turned. And at a cost of $400 also. I took my car to a local garage(kind of like a car cub) and rented a bay and I removed the rotors myself and took them in to get turned.(through my job we have access to repair equipment at a fraction and at times no cost) it is excellent equipment And thinking I was cutting cost that way, but within a day the loud squealing came right back. While I had the rotors off, I did rough up the pads with a little sand paper, I didn't spend to much time on this since I didn't want to go overboard. The pads have a lot of life left in them, what else could be causing this squeal?
Dec 31, 2009 at 11:04 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated I would replace the pads with new of a better quality .. they may have been replaced with inferior quality or defective pads the last time .. Hope this helps HAPPY NEW YEAR
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_932.png
Dec 31, 2009 at 11:21 PM
TAXES
How do I know if I am getting quality brakes or just ripped off?
Dec 31, 2009 at 11:28 PM
DAVE H
  • 13,384 POSTS
I would tend to opt for OEM (dealer supplied) parts ..If you go to an everyday parts store (autozone etc.) they generally give you 2/3 options and price ranges ..opt for one of the higher priced options as these tend to be the better quality pads .. Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_933.png
Dec 31, 2009 at 11:40 PM
TAXES
Is there any reason they would just start squealing out of the blue? Like I said for the first two months I didn't hear a thing.
I really hoping my next option wouldn't be to replace the pads. It has come across my mind. It's equipped w/ Brembo And I know they are going to be expensive.
Dec 31, 2009 at 11:51 PM
DAVE H
  • 13,384 POSTS
Low quality pads wear down to smooth surfaces over time ... You could try removing the pads, sand them down again .. also chamfer the leading and trailing edges of the pad to a 45 degree angle and use an anti squeal spray on rear of pad before replacing !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_934.png
Jan 1, 2010 at 12:13 AM
