1998 Range Rover brakes are hard to push
1998 ROVER RANGE ROVER
162,000 MILES • V8 • AWD • AUTOMATIC
JAIVERSON40
I replaced pads and rotors in rear. Fronts look fine and brake pedal still pushes hard and car does not stop well. All dummy lights are on too.
Aug 18, 2009 at 3:03 PM
  • 31,937 POSTS
You will need to get a scan to check for any fault codes, and i would be checking the booster and the vacuum supply as if this is faulty your brake pedal will be hard and high and very hard,
Mark (mhpautos)
Aug 18, 2009 at 3:15 PM
