2003 Range Rover steering is parcially soft
100,000 MILES • V8 • 4WD • AUTOMATIC
NIYI
i worked on the ignition key after the fixing and i started the jeep i noticed my steering [img:0ef9d15c67]http://www.2carpros.com/forum/automotive_pictures/362223_Snapshot_20090527_1.jpg[/img:0ef9d15c67][img:0ef9d15c67]http://www.2carpros.com/forum/automotive_pictures/362223_Snapshot_20090527_1_2.jpg[/img:0ef9d15c67]
was parcially soft. i changed the powersteering pump,steering rack yet the condition remains. please help me out
May 29, 2009 at 4:09 AM
THIS IS MIKE
  • 686 POSTS
make sure the rate sensor in the steering column is connected. When you worked on the the ignition switch you may have disconnected it. Your steering has a rate sensor that senses when you are going slow or fast and that may be causing the symptoms you describe.
Jun 1, 2009 at 5:35 AM
