Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Rover
Range Rover
Drivetrain
Transfer Case
Symptoms
Disengage
2001 Range Rover transfer case
2001 ROVER RANGE ROVER
84,000 MILES • V8 • 4WD • AUTOMATIC
AUTO4X4
MEMBER
1 POST
does worn out transfer case make clonk noise when the chain is stretched ?
Oct 29, 2008 at 2:55 PM
Experienced Mechanic
Hi there,
This should be a gear drive transfer not a chain, you may have a broken tooth in the gear train, drain the oil and check for metal.
mark (mhpautos)
Oct 29, 2008 at 8:26 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
