1999 Range Rover
JEREMIAH1
  • 1999 ROVER RANGE ROVER
  • V8
  • 87,366 MILES
The steering wheel shakes really bad once I reach 50 mph and how do I reset the radio code.3323
Wednesday, April 7th, 2010 AT 10:00 PM
DAVE H
  • 13,384 POSTS
Have the wheels balanced
SECURITY CODE
NOTE:If an incorrect code has been entered, the first time delay period commences. During the display period, "WAIT" appears in the display window. DO NOT switch off. At the end of the delay period, "CODE" reappears in the display window and you can then enter the correct code. The time delay period doubles each time an incorrect code is entered.
Whenever battery power to the radio is lost, the anti-theft code must be entered and the preset stations must be reprogrammed. The anti-theft code is located on the security card, supplied with vehicle literature pack. Obtain this card from the customer. To enter anti-theft code, perform the following:
Switch on the radio. The word "CODE" should appear in the display window. Press preset button "1".
Press either the "UP" or "DOWN" tuning button until the first digit of the security code appears in the display. Press preset button "1" to store the first digit in the unit's memory.
Use either tuning button to select the second digit of the code. After second digit appears in the display, press preset button "1" to store the second digit.
Select the third digit, using the tuning buttons. Press preset button "1" to store third digit.
Select the final digit (display should show the full four-digit code). Press preset button "1" to store final digit.
If the correct code has been selected, a two-tone beep sounds and the radio will operate.
Friday, April 9th, 2010 AT 4:20 AM
