1999 Range Rover
1999 ROVER RANGE ROVER
135,000 MILES • V8 • AWD • AUTOMATIC
EUGENE6177
I have a 1999 range rover 4.0S. I have coolant mixing with oil and need to find a solution. I have had all the gaskets changed recently but is is still overheating. I just took it in to land rover but they wanted 1500 to even break it down. what do you think is the problem. The person did use gasket sealer on the heads and intake manifold. Do you think that was a problem?
Oct 7, 2008 at 12:49 PM
DAVE H
  • 13,384 POSTS
have the cylinders compression tested .. could be a cracked or warped head ?
Jan 4, 2010 at 8:43 PM
