Considering buying this 98 Land Rover - Range Rover very well maintained & and all records. However after driving around the block the oil light comes on and a clicking sound starts (coming from the engine ie:-oil pump. No oil leaks.
Possible problem I want to check out ie: could the oil pump valve be partially stuck open and or could the pick up tube be plugged?
Or worse???
Or worse???
Nov 10, 2009 at 4:15 AM
