1998 Range Rover coolant is leaking from corner of timing c
1998 ROVER RANGE ROVER
98,000 MILES • V8 • 4WD • AUTOMATIC
CHUCK4467
i need a diagram of engine or need to know why coolant is leaking from this place never seen this happen before please help me
Apr 1, 2009 at 10:05 PM
ROVERTECHGOLD
  • 20 POSTS
The timing cover has 2 ports that hold coolant, so the leak could just be the timing cover gasket. Also, the right hand lower water pump bolt goes through the timing cover and threads into the coolant jacket. To seal this bolt, clean the threads and put teflon tape on the threads.
Apr 2, 2009 at 10:13 AM
ROVERTECHGOLD
  • 20 POSTS
https://images.2carpros.com/forum/automotive_pictures/333316_untitled_2.jpg
Apr 2, 2009 at 10:14 AM
