1997 Range Rover Range rover Starting problem
102,000 MILES • V8 • AWD • AUTOMATIC
MARKOLOMA
My range rover has many problems. but my most important one right now is that just today i turned it off an the starter will spin but not click or even crank the engine. ive read around and there are many different answers. bu none that worked. what might be the problem? for better detail, when i try starting the car the engine is silent and the starter sounds like its missing. just spinning.
Jan 22, 2009 at 12:39 PM
  • 75,988 POSTS
If the starter is engaging the engine and not turning over-the starter overrunning clutch is slipping.
Jan 22, 2009 at 8:03 PM
MARKOLOMA
And too prevent this... will i need to buy a new starter. thank you i appreciate you helping =D
Jan 26, 2009 at 3:55 PM
  • 75,988 POSTS
Yes, you do need to replace it
Jan 27, 2009 at 5:14 AM
