1997 Range Rover Range rover p38 1997 starting problem
PAT3D
Electrical problem
1997 Range Rover V8 Four Wheel Drive Automatic
I have a problem with my Range rover p38 1997.
It cannot start, the battery is new, the check engine light is on, but when I turn the key to start the car, nothing happens, and all the lights on the dashboard disappear. I don't have any click. And I had a smoke coming from the starter.
Any advice on that?
Thanks a lot for your help.
Pat
Sep 8, 2010 at 4:21 PM
DAVE H
  • 13,383 POSTS
check you are getting a hot feed to the starter .. if you are, you will need to replace the starter motor
Sep 12, 2010 at 10:46 AM
