1997 Range Rover
WILLHIND
Engine Performance problem
1997 Range Rover V8 Automatic
my 4.6 wont rev past 1500-2000 revs when hot its fine when cold but soon as it gets to a certain temp it starts spluttering and farting on and wont rev beyond 1500-2000 revs
Nov 4, 2009 at 7:13 AM
DR LOOT
  • 2,311 POSTS
As stated before, I think when you're mechanic did the head job, He may have forgotten to connect the temperature sending unit, or it got damaged during the head replacement, the reason I think that is, the temperature sending unit controls the fuel mixture at cold temperatures and hot temperature, as you described. It runs just fine when it is cold due to the fact that the computer is running a rich mixture, when the vehicle warms up the computer should lean out the fuel mixture According to the temperature, and because when the vehicle is hot it sounds like it's running rich,That might be caused by the temperature sending unit.
Nov 5, 2009 at 2:18 AM
