1996 Range Rover Starter Motor
1996 ROVER RANGE ROVER
134,000 MILES • V8 • 4WD • AUTOMATIC
SAMATT
I have an intermittent problem with my starter motor, sometimes it works ok and other times it sounds as if its not engaging the ring gear correctly. The car has been standing for a while without much use and the starter motor has been replaced. If I start it a few times in a row it gets better starting but if left for a while it then seems to be a problem to start?
Any ideas if this might be an electrical fault or mechanical?
Many thanks
Matt
Aug 10, 2009 at 12:27 AM
DAVE H
  • 13,384 POSTS
I would start by checking the wiring to the starter motor !
Aug 10, 2009 at 10:03 PM
