1995 Range Rover boiling water
38,000 MILES • V8 • 4WD • AUTOMATIC
RICKYA
i have a 1995 Range Rover 4.0 SE. The water boils after 20 minutes of idle and i just had the cylinder heads rebuilt and the gaskets replaced. The temp gauge stays halfway. The mechanic says that the engine block may have to be rephased and i don't want to spend so much on the car. Can you advise what other possible causes are for the boiling water? How can i check if the blocks really have to be rephased? Thank you in advance!
Dec 10, 2008 at 3:49 AM
DAVE H
  • 13,383 POSTS
check the water pump is working and have the cooling system flushed
Jan 4, 2010 at 9:05 PM
PASOROBLES-JOHN
The range rover shop in town has a procedure for every range rover that comes in with cooling issues, one of the first things they do is check the radiator.
I recently changed my head gaskets and evry other item having to do with the cooling system. after 20 minutes it would overheat, I pulled the radiator out and took it to a radiator shop, he said it was 70%plugged. I put it in and now it runs at halfway on the gauge, and doesnt go higher even in summer with ac on.....flushing radiator should be a yearly thing on a range rover.
Mar 10, 2010 at 8:51 AM
BRIANSPATZ
i have flushed the system and checked for air locks all fine water pump is ok
Dec 14, 2010 at 4:18 PM
DAVE H
  • 13,383 POSTS
Flushing the radiator does not alway's clear all blockages .. it could still be partially blocked ?
Dec 14, 2010 at 5:08 PM
