1994 Range Rover LEAK
100,000 MILES • V8 • 4WD • AUTOMATIC
DAZZLE1
WATER LEAKS INTO THE DRIVER AND PASSENGER FOOT WELLS, APPARENTLY FROM THE ENGINE BAY. WATER DOES ALSO LEAK FROM THE BOTTOM OF THE DRIVERS SIDE WING. THIS OCCASIONAL BUT IS GETTING MORE FREQUENT SO AM HAVING TO TOP UP THE ENGINE COOLENT. PLEASE HELP
Oct 6, 2010 at 6:37 AM
DAZZLE1
DONT KNOW
Oct 6, 2010 at 6:38 AM
PEDRAMBASTAN
Your Heater core is cracked. It's a plastic radiator inside the car under the dash in the worst place possible. I have had one explode and steam up the front windshield while driving. Had to pull over and tow it home. They are common on the Range Rover Classics. You need to remove the entire dash to access it. It's a good days worth of work. It's hidden in the black plastic box with the vent controls in the center towards the passenger floor. Two lines run in from the engine bay. Inlet and outlet.
Nov 9, 2012 at 9:06 PM
