The engine cranks. But doesnt start.
please help me.I changed the starter, coil, distributor cap. And distributor.I check the safety switch under the driver seat. Its in the right position.
Friday, January 30th, 2009 AT 9:03 AM
RRWOWS
MEMBER
Have you checked that fuel is getting through?
If you have spark at the plugs its probably a fuel pump issue. If no spark check if you are getting spark from the coil then its a matter of tracing back from there.
