wrrring noise
2001 LAND ROVER
105,000 MILES • V8 • 4WD • AUTOMATIC
DAVE H
  • 13,384 POSTS
It seems like ineed transmission fluid but I dont know how to check it can I do it without going to the dealer
Nov 27, 2009 at 1:37 AM
DAVE H
  • 13,384 POSTS
check power steering fluid ..
DRAINING & REFILLING
Replace Oil
Ensure that gearbox is cool. Apply handbrake and securely chock front and rear wheels.
Place a suitable container beneath gearbox.
Clean area around oil filler/level and drain plugs.
Remove oil drain plug, remove and discard sealing washer. See Fig. 2.
Allow oil to drain.
Fit new sealing washer to oil drain plug.
Fit automatic gearbox drain plug and tighten to 15 Nm (11 lbf.ft).
Remove oil filler/level plug, remove and discard sealing washer.
Fill gearbox with recommended oil to bottom of oil level/filler plug hole.
Select Park.
Ensure handbrake is applied.
Start engine and allow it to idle.
Apply footbrake.
Move selector lever through all gear positions, while continuing to fill the gearbox. Select Park.
With engine idling, continue filling gearbox until a 2 mm bead of oil runs from oil filler/level plug hole.
Fit new sealing washer to automatic gearbox filler/level plug, fit plug and tighten to 30 Nm (22 lbf.ft).
Stop engine.
Remove all traces of oil from gearbox casing.
