1994 Other Rover Models land rover quest
1994 LAND ROVER
103,000 MILES • V8 • 4WD • AUTOMATIC
FRANKYBOY
my engine runs rough, shakes alot unstable,rpm's goes up and down on idle,when a spark plug is unplugged you can berely notice somthing shakes on all cylinders. ive lost the power on the engine, whe the car is running on normal temperature if i step on the gas ive notice theres water on the moufler pipe not much but always, now my question does it has something to do with my headgasket?? please reply if anybody knows something about it
Jan 5, 2008 at 10:06 AM
BLACKOP555
  • 10,386 POSTS
if you dont have alot of white smoke coming out then its not the head gasket, and the moisture is then just water in the gas, and is common on a lot of vehicles.
clean out your throttle body, clean your iac, and clean out your EGR valve, also you should replace your PCV valve every 15000 miles.
Jan 5, 2008 at 11:59 AM
