1996 Other Land Rover Models missfiring
1996 LAND ROVER
PETECROSS577
Electrical problem
1996 Other Land Rover Models V8 Four Wheel Drive Automatic 160.00 miles
I have changed the cat, coil,ht leads,and plugs.
When starting is firing on all after driving for a while will suddenly misfire then after a while will clear it's self then run fine for about 10 miles then the same thing happens.
It will do the same on petrol as it with LPG
Jan 7, 2010 at 5:52 PM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 7, 2010 at 5:57 PM
DAVE H
  • 13,383 POSTS
try Removing and cleaning or replacing the CKP (Crankshaft position sensor)
Jan 7, 2010 at 9:56 PM
