2005 Land Rover Freelander REMOVAL OF REAR PASSENGER DOOR T
2005 LAND ROVER FREELANDER
60,000 MILES • 4 CYL • 4WD • MANUAL
LALFORBES
Hi
Can anyone please help with instructions as how to remove the door trim on one of the rear passenger doors. I believe this is different from the first model of the Freelander. My own car is the updated model 2005.
I want to remove the electric window regulator but cant see where to start dismantling the trim and dont want to break anything.
Thanks for any assistance
Les Forbes
Jul 20, 2009 at 6:13 PM
DAVE H
  • 13,384 POSTS
REMOVE
Remove screw securing door release escutcheon and remove escutcheon.
Release and remove door pull finisher from door pull.
Remove 3 screws securing door pull to door assembly.
Release trim casing from door assembly.
Disconnect multiplug from door tweeter.
Disconnect multiplug from window lift switch and remove trim casing.
NOTE:Do not carry out further dismantling if component is removed for access only.
Release 2 clips and remove window lift switch finisher from trim casing.
Remove locking ring securing tweeter to trim casing and remove tweeter.
Remove foam pad from sill button guide.
Release retainer and remove sill button guide.
Note the fitted position of the 2 long trim studs and remove 9 trim studs from trim casing.
Release and remove locking ring securing door pull to trim casing.
Remove 2 plastic rivets securing door pull to trim casing and remove door pull.
NOTE:Plastic rivets are used for production purposes only. Screws should be used to retain all parts previously held in place with plastic rivets.
REFIT
Oct 30, 2009 at 9:56 PM
