2002 Land Rover Freelander rear tail window
2002 LAND ROVER FREELANDER
OMAR1
Electrical problem
2002 Land Rover Freelander 4 cyl Four Wheel Drive Automatic
my freelander rear tail window is not working i changed the fuze box,i checked the window motor and thats working fine, i followed the whole wire harnes, i also tried disconnecting the battery and then reconnected it the window did go down but did not work with the switch only by direct power , i have changed the switches and nothing has worked
Oct 15, 2009 at 12:35 AM
DAVE H
  • 13,384 POSTS
There was a TSB issued regarding a software error in the control unit .. have a dealer check this for you !!
Oct 20, 2009 at 9:07 PM
