2002 Land Rover Freelander p147. and sometimes dies when i
112,000 MILES • 6 CYL • AWD • AUTOMATIC
STEVEOUSMC
hi my name is steven I have a 02 land rover freelander and I've been having trouble with it it has trouble starting up like its getting no gas so I have to push on the gas to get it started so I hooked up a code reader and I'm getting the code p1471. And I did a live data check and it says I'm only getting 35 for the pressure and 0 on the fuel rail. And sometime when I'm driving and press on the gas the rpm will shoot up but my speed will stay the same or drop and the service engine soon light will come on. So I replaced the fuel pump both vis motors the intake manifold and my plugs and wires and its still doing the same thingwhat else could it be?
Jul 24, 2010 at 9:18 AM
DAVE H
  • 13,383 POSTS
Are you stll getting the same fault code ?
P1471 VIS Balance Valve Motor, Valve Always Closed
Jul 25, 2010 at 9:12 PM
STEVEOUSMC
Ya the code p1471 is still up even after I erase the codes. But why would the car die? I have to keep pressing the gas to keep it running.
Jul 26, 2010 at 3:13 AM
DAVE H
  • 13,383 POSTS
check the wiring to the VIS motors
Jul 27, 2010 at 8:22 PM
STEVEOUSMC
how do I check them what's the best way? And I'm also getting codes p1319 p0171 p1471 p1472 any ideas?
Jul 28, 2010 at 3:46 AM
