2002 Land Rover Freelander differential
150,000 MILES • 6 CYL • AWD • AUTOMATIC
SCOTTYROMERO
I changed the seal on differential and retightened nut on front, now I have a noise when backing up, is the nut supposed to be torqued, and if so what are specs?
May 17, 2009 at 3:27 AM
DAVE H
  • 13,383 POSTS
Rear Differential Pinion Nut (2) (3) Ft.Lbs 140 Nm(190)
(2)DO NOT reuse old nut or bolt.
(3)Continue to tighten pinion nut until pinion preload torque-to-turn is 15.0-24.8 INCH Lbs. (1.7-2.8 N.m). If pinion preload is higher, replace collapsible spacer. DO NOT tighten pinion nut to more than 275 Ft. Lbs. (373 N.m), or collapsible spacer will be compressed too far
Oct 30, 2009 at 9:39 PM
