2002 Land Rover Freelander blinkers won't work
104,000 MILES • 6 CYL • AWD • AUTOMATIC
C2MAS
Hi, all
I check all the bulbs and fuse they all ok. then i replace the flasher and turn signal switch the same problem won't blink. then i check the emergency signal and all them are blinking front and back.what would be the problem..
thanks for ur time..
May 4, 2010 at 5:23 AM
DAVE H
  • 13,383 POSTS
replace the Flasher Unit In passenger compartment fuse box.
May 8, 2010 at 8:22 PM
C2MAS
[quote:db675f6bd3="Dave H"]replace the Flasher Unit In passenger compartment fuse box.[/quote:db675f6bd3] Dave, you know the problem is the daylight running module.And the sad part is the dealer told me they don't make the parts. they say just hard wire and make another circuit and end going to auto electrical shop.Finally its working now.
thank you very much guy's for your support. ciao....
May 17, 2010 at 2:45 PM
DAVE H
  • 13,383 POSTS
thanks for letting us know your final fix .. this will help users in the future ..
thanks again
Dave H
May 21, 2010 at 9:33 PM
