1988 Land Rover Freelander Poor starting when cold
99,000 MILES • 4 CYL • 4WD • MANUAL
DAVEDONNY
First thing in the morning this diesel Land Rover will not start until it has been cranked for about a minute, once it has started it runs well and re-starts first time.
During this cranking the engine is turning over but not firing, until it starts then it will emit white smoke for a few seconds.
All injects have been check and are OK.
There is no fuel fall back or air in the fuel line.
The timing is correct (engine timing marks).
The compression is Ok if slightly low.
Any suggestions ?
Sep 30, 2009 at 9:55 PM
DAVE H
  • 13,383 POSTS
replace the glow plugs !
Oct 30, 2009 at 10:00 PM
