2006 Land Rover Discovery 3 TURBO
2006 LAND ROVER DISCOVERY 3
46,000 MILES • 6 CYL • 4WD • MANUAL
WOBBLE
AT ABOUT 2500rpm THE TURBO KICKS IN, THIS HAS JUST SUDDENLY HAPPENED AND REALLY AFFECTED THE CARS BOTTOM END PERFORMANCE IS THIS AN EASY FIX?
Jul 27, 2010 at 6:24 PM
  • 31,937 POSTS
Hi there,
You will have to check that the waste gate is not sticking open, this will bleed turbo boost, also have the inter cooler checked for a crack you can loose boost here but this will sound like a whistle or even a slipping belt type noise, start here.
mark (mhpautos)
Jul 28, 2010 at 1:05 AM
