2005 Land Rover Discovery 3 Alternator Replacement
2005 LAND ROVER DISCOVERY 3
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
SANDER76
I need to replace the alternator on my LR3 Disco Automatic.
Any advice, is this straight forward......?? I'm a complete novice.
Feb 10, 2010 at 9:45 PM
DAVE H
  • 13,384 POSTS
Removal & Installation
Disconnect battery. Remove accessory drive belt.
Remove 2 bolts securing generator to mounting bracket.
Release generator from mounting bracket.
Remove nuts securing generator leads, and release leads.
Remove generator from mounting bracket.
Remove pulley from generator.
Installation is reverse of removal procedure. Tighten nuts and bolts to specifications. Connect battery.
After repairs verify generator operation
Mar 13, 2010 at 11:02 PM
