2003 Land Rover Discovery 2 Repair of Power Door
15,000 MILES • V8 • AWD • AUTOMATIC
RLEIGHTON
Window off track. Need to remove door panel to re-align window.
Jul 31, 2010 at 5:58 AM
DAVE H
  • 13,383 POSTS
RONT DOOR TRIM PANEL
Removal & Installation (Discovery Series II)
Remove 2 screws securing hand rail to door. Remove door handle escutcheon. Remove 4 door pocket screws and remove door pocket. Carefully release 10 clips securing trim panel to door. Disconnect upper and lower speakers electrical connectors. Remove door trim panel. To install, reverse removal procedure.
Removal & Installation (Range Rover)
Release cheater panel. Disconnect 2 tweeter speaker connectors and remove cheater panel. Remove screw securing remote handle escutcheon and remove escutcheon. Remove 3 screws securing trim panel. Release 12 clips retaining trim panel. Disconnect speaker connector. Remove door trim panel.
REAR SIDE DOOR TRIM PANEL
Remove screw securing door handle escutcheon to door. Disconnect window switch electrical connector. Remove door handle escutcheon. Remove 2 screws securing hand rail to door. Carefully release 11 clips securing trim casing to door. Disconnect upper and lower door speakers connectors. Remove trim casing from door. To install, reverse removal procedure.
Remove screw securing remote handle escutcheon and remove escutcheon. Remove 2 screws securing trim casing to door. Release 11 door trim casing retaining studs. Disconnect rear door speaker and remove door trim. To install, reverse removal procedure.
Aug 23, 2010 at 8:51 PM
