2003 Land Rover Discovery 2 gear shift
119,500 MILES • V8 • 4WD • AUTOMATIC
RAFA1962
Do not move from parking,
just start and I try to chenged my to drive and do not let me do it.
can you tell me a problem cause.
how I can fix it.[img:944de844d5]http://www.2carpros.com/forum/automotive_pictures/414697_hands3_1.jpg[/img:944de844d5]
Sep 27, 2009 at 2:37 PM
DAVE H
  • 13,383 POSTS
GEAR SELECTOR LEVER INTERLOCK
The interlock solenoid on the selector lever is de-energized unless the foot brake is applied while the ignition is on. While de-energized, the interlock solenoid allows the selector lever to move through the range unless P is selected. On entering the P position, the interlock solenoid engages a latch which locks the selector lever. When the ignition is on and the foot brake is applied, the Body Control Unit (BCU) energizes the interlock solenoid, which disengages the latch and allows the selector lever to be moved out of P.
Oct 30, 2009 at 10:11 PM
