2002 Land Rover Discovery 2 wont start
105,000 MILES • V8 • AWD • AUTOMATIC
ROBGREV
my 02 landrover discovery wont start iv checked the fuel pump and it checks out, all the relays check out as well. m not getting any spark and herd that it could be my crank shaft sensor so i pulled it and checked the olms and it seems fine could it still be the sensor or should i look somewhere else?
May 24, 2010 at 3:39 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
May 24, 2010 at 10:40 PM
