First of all this issue is 7 years old. It all started back when the car reached 25,000 miles our brakes were worn down to the rotors and supposedly this is normal. I took my car to a local mechanic who is very knowledgeable who used a combination of brake pad material and rotors that would last longer. Shortly after the ABS and TC would beep and light up on the dash i.e., disabled.
I went to the dealer and they tested all the wheel sensors and said they were fine so problem was we do to not using factory parts and the sensors are very sanative so… the only way to fix this is to swap out the new brakes/ rotors and replace with factory pads and rotors. And if that does not work thy might need to replace some sort of ABS controller box.
I have a hard time believing this but I wanted some expert advice.
Thanks,
Mike
PS we went 52,000 miles before replacing to the next set of pads and rotors
Thanks,
Mike
Oct 10, 2010 at 2:33 AM
