2001 Land Rover Discovery 2 power seats
96,000 MILES • V8 • 2WD • AUTOMATIC
JUSTAR
only 4 adjustments work on my 6 way power seat control. The seat risses and falls and tilts. It will not move back and forth. All fuses are good and connections are good.
What could the problem be?
Apr 9, 2009 at 6:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Power supply for each seat switch pack is supplied froma seat assembly relay, located on the seat frame under each seat. I suggest first inspecting this relay. If the relay is OK, suspect faulty seat switch pack.
Thanks for using 2CarPros.com!
Apr 9, 2009 at 6:49 AM
