2001 Land Rover Discovery 2
BLADI5
Engine Performance problem
2001 Land Rover Discovery 2 V8 Four Wheel Drive Automatic
p0307 injector 7 excees emissions catalyst damaging level of misfire what is the problem please
Feb 19, 2010 at 11:18 AM
2CARPRO JACK
  • 11,533 POSTS
P0307 is a misfire cylinder 7 code.Could be a bad coil, plug wire (If applicable) or bad injector.When engine is warm, use a meter to test across the injector and compare it to one next to it.This should tell you if the injector is shorting internally.Also you could check for spark using a spark tester.
Feb 21, 2010 at 12:23 AM
