2000 Land Rover Discovery 2 very bad miss
91,000 MILES • V8 • AWD • AUTOMATIC
LATILLMAN14
I have several lights on the dash. Service engine light flashes until the it gets warmed up. ABS, Traction control, and jake break lights are all on. It has a bad miss in it I have had plugs and wires changed, intake gasket, and fuel pump replaced. None of which helped the miss in the engine. It has no power when taking off. Once I get to 55 it seems to do better. If you touch the gas while it is warming up, the service engine light will not stop blinking and it has no power.
Apr 12, 2010 at 12:48 AM
DAVE H
  • 13,383 POSTS
check the brake fluid level is good .. have the vehicle plugged into a diagnostic computer to retrieve the fault codes and repost with codes for more assistance .. this may be a simple coil fault .. the codes will aid in diagnosis !
Apr 14, 2010 at 7:49 PM
