2000 Land Rover Discovery 2 how to take the fan off the fr
140,000 MILES • V8 • 2WD • AUTOMATIC
LEONARD WALLER
how to take it off and which way do you turn it
Mar 22, 2010 at 2:34 AM
DAVE H
  • 13,383 POSTS
REMOVAL & INSTALLATION
ELECTRIC COOLING FAN
Removal
Release fasteners, remove battery cover and remove right turn signal. Release fasteners and remove left turn signal. Remove headlight access cover from body. See Fig. 1 .
Remove screw securing turn signal to body and release light from 2 locating peg sockets in fender. See Fig. 2 . Disconnect 2 connectors from turn signal and remove light.
Remove screws securing headlight finishers via access hole in wheel arch liners. See Fig. 3 . Remove headlight finishers from grille. Remove 2 screws securing lower corners of grille. See Fig. 4 . Remove 3 scrivets and remove grille.
Remove 2 bolts securing hood platform right support stay. Remove support stay. Disconnect connector from condenser cooling fan motor.
Remove 4 screws securing cooling fan cowl to mounting bracket. Remove cooling fan assembly and collect spacing washers.
Mar 23, 2010 at 12:26 AM
