Hi there,
Thank you for the donation,
This code is for a fault in the CAN system, (Controlled Area Network) but this raises two questions, firstly this is a system that reads multi signals from sensors and must be re scanned for sub categories, but with saying that, I do believe that your disco plated 2000 will not have CAN. Did you have this scanned with a factory scanner, as that is about all you can use on these cars to get an accurate reading?
P1884 (11) * CAN message: Engine friction invalid No apparent effect. On Off
P1884 (18 ) * CAN message: Throttle position invalid Substitute throttle angle of 50% adopted. No kickdown. Operates in economy modes only. On On
P1884 (19) CAN message: Engine temperature invalid Substitute engine temperature derived from other inputs. No apparent effect. On Off
P1884 (20) CAN message: Road speed invalid No apparent effect On Off
P1884 (33, 34) * CAN message: Engine torque invalid Substitute engine torque of derived from other inputs. May affect shift quality. On Off
P1884 (35) * CAN message: Engine speed invalid Maintains current gear in low range, limp home mode in high range. Shift pressure to maximum, harsh gear shifts/engagement. On On
P1884 (37) CAN message: Engine air intake temperature invalid No apparent effect. On Off
Mark (mhpautos)
SPONSORED LINKS
Tuesday, May 4th, 2010 AT 6:47 PM
