1999 Land Rover Discovery 2 water pump
167,000 MILES • 4 CYL • 4WD • AUTOMATIC
JACK MERDOCK
water pump
Sep 3, 2010 at 2:45 PM
DAVE H
  • 13,383 POSTS
WATER PUMP
NOTE:Note bolt length and location during removal. Different length bolts are used and must be installed in original location.
Drain cooling system. Loosen 3 water pump pulley bolts. Remove auxiliary drive belt. Remove water pump pulley. Remove coolant hose from water pump. Remove water pump. To install, reverse removal procedure. Tighten bolts to specification.
Sep 12, 2010 at 11:02 AM
