1999 Land Rover Discovery 2 Squeaky noise when Acceleratin
1999 LAND ROVER DISCOVERY 2
125,000 MILES • V8 • AWD • AUTOMATIC
HWAIRE22
Whenever I'm at a complete stop and start to accelerate i hear a squeaking noise coming from underneath likes somethings dryed out. It never makes the sound when I'm in neutral or park giving it gas only when i accelerate driving there is also a tiny bit of vibration. I thought it might be the brakes so i change them all out also changed the oil and the transmission still doing it also here is a video link of the sound http://s668.photobucket.com/albums/vv41/hwaire/?action=view¤t=1111111001.flv
Jan 18, 2010 at 4:28 PM
DAVE H
  • 13,384 POSTS
check/replace wheel/hub bearings
Jan 30, 2010 at 9:52 PM
NSPAIN
I have exactly the same problem (identical sound) and also though it was a dry joint somewhere. I oiled them all but it made no difference, I think it may be from the belt but I don't know how to increase the tension on the belt.
I would be grateful to hear if you have solved it.
Feb 6, 2010 at 1:53 AM
HOLDERGT
YOU HAVE TO CHANGE THE FRONT DRIVE SHAFT I HAD THE SAME PROBLEM
Jun 5, 2010 at 9:52 AM
HOLDERGT
change it before it break and you hit the tranmission
Jun 5, 2010 at 9:53 AM
