1999 Land Rover Discovery 2 rear air suspension
GORDON664
  • 5 POSTS
Suspension problem
1999 Land Rover Discovery 2 Four Wheel Drive Manual 142000 miles
i have a problem with the vehicle wandering, especially at speed. even in a straight line, i am constantly having to trim (adjust) the steering.
i do not think it is the steering, i think its the suspension. all of the vehicle has been checked and ok'd by its annual inspection.
the only other difference is that a previous owner removed the rear air suspension and fitted normal coil springs with a standard conversion kit
i am tempted to remove the coil springs and fit a proper conversion kit back to air suspension but berore i do, i want to know if it will make much difference
Nov 29, 2009 at 6:34 AM
DAVE H
  • 13,383 POSTS
The rear suspension will not generally cause the vehicle to wander on the road .. !
Dec 30, 2009 at 9:19 PM
GORDON664
  • 5 POSTS
thanks for the reply, its my brother in laws discovery 2.
so its probably not the suspension then. he was of the opinion it was a botch conversion to springs job.
what else can cause the wandering ?
gordon664
Dec 31, 2009 at 12:55 AM
DAVE H
  • 13,383 POSTS
check front tyre condition/balance and alignment .. also check front suspension mounting's/bushing's and ball joints etc. ... you could also check front brake pads are not sticking !
Dec 31, 2009 at 8:56 AM
GORDON664
  • 5 POSTS
hi
thanks for the help by the by.
is'nt all that checked by the mot ? if it passes the mot, that lot should be ok ?
maybe not!
gordon664
Dec 31, 2009 at 7:24 PM
DAVE H
  • 13,383 POSTS
wheel alignment and balance are not checked on MOT ..
Dec 31, 2009 at 11:09 PM
