1998 Land Rover Discovery will not charge when icut lights
1998 LAND ROVER DISCOVERY
TIMOTHY PEERRYMAN
Electrical problem
1998 Land Rover Discovery V8 Four Wheel Drive Automatic
will not charge when icut lights on and the belt squills when i cut lights on
Jan 21, 2009 at 7:31 AM
DOITYOURESELF
  • 48 POSTS
Have the battery and generator tested, at most any major auto parts store its free. your generator(or alternator if you prefer) has probably failed, causing the belt to squeal from severe resistance. You may need a belt also, they can check that for you too.
Jan 22, 2009 at 9:45 PM
