1997 Land Rover Discovery LOST POWER WHEN DRIVING
110,000 MILES • V8 • 4WD • AUTOMATIC
GODWINMD
I start the truck and it idles and runs fine at all RPM's and revs up just fine.
When I drive the truck and begin accelerating the truck runs fine for the first 10 or 15 seconds , then the truck begins to sputter and loses power.
The longer I drive the truck the more power it loses. after a few minute of driving the trucks the max speed is around 20mph .
I have replaced the in-line fuel filter and I still have the probelm. I also about a week ago put some BG-44K in the fuel system but thats had no effect.
Any ideas ?
Jul 19, 2010 at 12:36 PM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 19, 2010 at 1:07 PM
GODWINMD
Thanks for the respnse.
I pluged in a OBD2 - code reader and it came back with the following codes
P0130-- ---02 CIRCUIT (BANK 1 SENSOR 1)
P0306 --- CYLINDER 6 MISSFIRE DETECTED
P1313 ----MISSFIRE RATE CATALYST DAMAGE FAULT - BANK 1
P1316 ---- MISSFIRE RATE EXCEEDS EMISSIONS
IM THINKING THIS COULD BE AN OXYGEN SENSOR ?
ANY HELP WOULD BE GREATLY APPRICIATED.
THANK YOU.
Jul 20, 2010 at 5:15 PM
