1995 Land Rover Discovery shifter stuk in park
1995 LAND ROVER DISCOVERY
K B
Transmission problem
1995 Land Rover Discovery V8 Four Wheel Drive Automatic 140k miles
shifter stuck in park. shift button pushed in, brake on, even tried disconecting and reconecting battery. have secondary problem with ignition, key wont come out. could this be related?
Feb 28, 2009 at 7:17 AM
DAVE H
  • 13,384 POSTS
you need to change the ignition switch if it is not coming all the way back and releasing the key !! the gear seslector will not be allowed to move with ket switch stuck in the wrong position
Feb 28, 2009 at 12:36 PM
