1995 Land Rover Discovery IAC problems
197,000 MILES • V8 • 4WD • AUTOMATIC
DEVIL-SLAYER
my IAC motor works and i clean it well every month ,,,,,, my question is very simple , how should i adjust it , what is the perfect adjustment for a discovery 1995 ??
i`m a very simple person so please try to answer me in a simple way such as how many cm or mm should the head be protruding exactly so i get the best performance ,,,
Mar 17, 2010 at 12:39 AM
DAVE H
  • 13,383 POSTS
No adjustment's are possible .. just cleaning or replacing the valve ! IDLE AIR CONTROL VALVE Removal & Installation Disconnect battery negative terminal. Remove connector from Idle Air Control (IAC) valve. See Fig. 14 . Unscrew valve from its location at rear of plenum chamber. Remove sealing washer. To install, fit a NEW sealing washer. NOTE:If same bypass valve is being refitted clean any previous sealing compounds from threads. Apply Loctite 241 to threads of valve before reassembly.
https://images.2carpros.com/forum/automotive_pictures/266999_land_27.jpg
Tighten valve to specified torque. See TORQUE SPECIFICATIONS . To complete installation, reverse removal procedure.
Mar 17, 2010 at 8:17 PM
DEVIL-SLAYER
thank you , that hellped alot
Mar 18, 2010 at 12:38 AM
DAVE H
  • 13,383 POSTS
No problem .. please feel free to use our forum in the future and spread the word of our forum to friends and family etc. etc. Happy Motoring
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1079.png
Mar 18, 2010 at 1:35 AM
