1991 Land Rover Discovery transfer case
DOUGLAS41
Transmission problem
1991 Land Rover Discovery V8 Four Wheel Drive Manual
I HAVE A MAY 1991 DISCOVERY 4 WHEEL DRIVE MANUAL I NEED TO REMOVE THE TRANSFER CASE.
I HAVE REMOVED THE THREE BOLTS AND THE ONE
NUT AT TOP OF CASE AND ALL OTHER CONNECTIONS. THE CASE WILL NOT MOVE NOT
GAME TO APPLY MUCH PRESSUIRE DUE TO THE MATERIAL IT IS MADE FROM. AS FAR AS I CAN SEE THERE ARE NO OTHER BOILTS ETC. I HAVE DRIVEN A SCREWDRIVER BETWEEN THE FACES BUT IT WILL NOT MOVE.
HOW DO YOU SUGGEST.
Aug 1, 2010 at 5:29 PM
DAVE H
  • 13,383 POSTS
check for more bolts holding the case in place .. also there are usually 2 side mounting plates/bolts
Aug 23, 2010 at 8:57 PM
